proto 1000 rs-2
UP SD40-2
2,709
radar said:
Has anyone put a decoder in a proto 1000 rs-2 ? I have 2 of them coming from walther's:D
radar:wave:, i haven't put a decoder in an RS-2, i don't have one. HOWEVER, i know Proto circuit boards are VERY DCC friendly;), you should have no problem installing a decoder in it:thumb:. on SOME of the Proto 1000's i have had to replace the bulbs after making them DCC though, not all of the bulbs in them are DCC compatible:(. :D -Deano
nhguy
89
Sugar City,Colorado
rides.webshots.com
You can use a NCE DA-SR, TCS T1 or just about any other hard wired decoder. I used the TCS T1 and the NCE DA- SR. I have 4 of the RS-2's. I personally like to remove the P1K board and hard wire it. I just find it easier to do but that's me. There is also enough room for a Soundtraxx DSD Alco sound decoder. But you have to mill out the fuel tank to put a speaker in there so I haven't tried it except to test fit a DSD I have. I also changed the light bulbs to Miniatronic Yelow-Glo LED's with a 480 ohm resistor. They run great.
