Project S.A.M.
9,550
Is it just called "Inventor"? ;)
9,550
Wow, I feel like a dumbass. :wacky:
retunga
Designer
Jan 15, 2012
174
106
Planet Earth
www.watch_this_space.com
Hey All
update time again, I have now completed the head design with movement up and down and left and right.
On the top of the head is a search radar disc, a lot like the AH-64 longbow as a means of defence.
Next part is the main body to house the head and arms and ect.
This will take a bit of time to get right in the way that I want to look and work.
R
retunga
Designer
Jan 15, 2012
174
106
Planet Earth
Update Time....
For the last few weeks now I have been busy with the lower cabin and chassis design for the head and arm mounting points, So I am showing is the Chassis for the engine and wheels for now.
Chassis:
Engine or reactor:
Engine in the Chassis:
The work will continue with the rest of the Cabin and Head mounting points, there is afew things tha tI want to do but it is just working out the movements to get it to work as I want it is the problem at head.
R
retunga
Designer
Jan 15, 2012
174
106
Planet Earth
Hi All
update time, the updates that I have now completed is the cab with the head assembly that will now go in and out, 3 redesigns later but it is now done.
Here is a cut away of what the head movement is going to look like.
Truck front end closed up.
cab movement leavers for the head.
Section view of the head in the cab with the front moving panels in place.
Current work in progress state of the model.
R
retunga
Designer
Jan 15, 2012
174
106
Planet Earth
Update time again.
I can say now that the design work for the first of 3 phases is now complete.
Phase 1: SAM (transformer)
Phase 2: Weapons trailer
Phase 3: Weapons.
What I am going to do next is to start flatten out the parts into patterns and build the transformer frist then complete the 2nd and 3rd phase of the project.
The renders are not the best as my laptop was taking a time to get the render complete but the pictures will show what the model will look like at the end of the day baring a few extra parts that I have not added to the design yet.
completed closed transformer.
Without the shield.
Full transformer mode.
R
retunga
Designer
Jan 15, 2012
174
106
Planet Earth
Hi all
Bit of an update, at the moment I am busy flatting all of the parts for the model and I am about 85% complete with that part, I have not as of yet set any pages up.
What I have done is to start with the assembly drawings mostly on the lines to start getting the model part pages setup in the correct order and also to see if there is extra parts needed to keep the model strong when the model is completed.
here is a 4 sample page of where I am at this moment in time.
Main assembly drawing with some sizes.
Enjoy, more updates to follow.
R
Reactions: Revell-Fan
DanBKing
Dan the Man
Feb 29, 2012
1,817
1,587
Netherlands
:surprise:
That's brilliant!!
What program do you use to create those assembly drawings...?
I've always had a thing for tech manuals, and those pics would fit the "Haynes Manual - Elite" editions...... ;)
retunga
Designer
Jan 15, 2012
174
106
Planet Earth
Thanks, with Autodesk inventor you create your design and do the assembly of your design and from there you setup a presentation of how it all fits together. From there you insert it into drawing with all normal bells and whistles and you get the drawings that I have just shown.
Does take a bit of time but it is worth it for double checking
