problem with rustler PLEASE HELP
Discussion in 'RC Offroad Forum' started by rustler, May 17, 2004.
Thread Status:
  1. rustler
    rustler Member
    Today i was out driving my nitro rustler and i had a hard time getting it to run, but when i did I would first start out slow about 10 mph then when i went to full throttle it kept going the same speed. if anyone knows what the problem could be please let me know
    Thanx
  2. dj6666969
    dj6666969 Active Member
    sounds like the engine needed ot be tuned
  3. rustler
    rustler Member
    do you think that i was running it to lean
  4. dj6666969
    ya eather it is to lean or to rich but with a rich setting the engine would be alittle slugish at acceration and if that is the problem then it is running to rich. With the lean setting the engine will run but at high rmp's or full throttle it might stall or bog out because the engine is not getting enuf fuel to air which means its not firing right. Did that help at all lol?
  5. rustler
    rustler Member
    Yea it helped a lot i will go and try that out
  6. dj6666969
    k sounds good post back how it went!
  7. rustler
    rustler Member
    bad news my pull start broke so i counldnt drive it some time this week i think i am goin to go get a rotto start but do you know if one of them would be able to fit on a nitro rustler
  8. atc1100rider
    atc1100rider Member
    just get a electric srill in the mean time to start it
  9. rustler
    rustler Member
    Are you sure that will fit my nitro rustler with the old trx 15 engine
  10. dj6666969
    a drill wouldnt work on the 1 way bearing because the exhaust is right there so that is out of the question. What you could do is use a bump start or a starter box to start it. This will save some weigh( no pull start!) All this does is it startes the rustler useing the fly wheel. The wheel on the bump start or a staring box makes a connection with the flywheel and it turns the engine over, its cool because then ya dont have to crank on it with the pull start. The only down fall is it is hard to tell if the engine floodes or not.
Thread Status:
