Printing on Plastic Card
Discussion in 'Extended Mediums' started by NYC Irish, Nov 29, 2007.
  1. Jef
    Jef New Member
    I use plotter.Worked with tin film.Not sure about Evergreen.
  2. Tirick
    Tirick Member
    I have very successfully used full sheet sticker paper to print onto and then adhere to the styrene sheet. Works very well, quite secure while cutting. The only trick is the removal, which requires rubbing alcohol (I soaked the part overnight usually).
    I assume you want styrene to make your own paint schemes, improve durability and or modify. If you want the actual paint schema on plastic, this method does not work too well...
