I have an MRC Tech 220 controller with the momentom feature. First of all, what is the reason for this feature? Is it for more realistic start ups and stops or what? Secondly, when my IHC 4-6-4 hits the short straight sections of either oval, the 18 radius or the 22" radius, if going slowly, only pulling four cars, it will hesitate for a moment and sometimes stop. If I increase power, it will not move until nudged slightly. If speed is up, it will make it through with quick, snappy hesitations at those same points. My 2-10-2 and 2-10-0 and switcher diesel show a very slight hesitation if at all, through the same areas of track. I saw, in one of the threads recently, that sometimes , other sections of the track may need to be connected to the controller along with the original connection. Would direct connections to these straight sections possibly solve this problem? Tracks are clean, how do you clean the pick-up wheels on a tender or an engine? Also, what is the best or proper way to pick up say a 2-10-2 when removing from track? Thanks in advance for your patience and advice----John R
