SteveInBama
I'm a new guy - needing more info on what track block configuration/power districts would be best for an "L" shaped layout with two parallel HO tracks. (total layout length 21'long x 5'wide, 1 dbl xover, and later, 1 reverse loop). I expect to use Digitrx Super Chief,5amp - DT400- with only 4 loco's - ...potential later expansion. Part of my concern is ease of operation/trouble shooting/simple wiring design ... And how many boosters I should plan in my initial layout design.
Will a "better" configuration of boosters and blocks help to ensure everything else does not stop &/or... it will be protected when there a problem?
I'm using the 3 basic MRR books as basic guides DCC Made Easy / Projects / Guide. --- but learning a lot from this forum.
Thanks for any tips or specific references.
SteveInBama
SteveInBama
