Poster board backdrops
Pitchwife
Dreamer
Apr 23, 2001
1,728
The middle of nowhere Oregon
I am thinking of using poster board (actually it's heavy cardboard) to paint my backdrop on. the pros are that it is flexable to go around the rounded corneers, it is easily mounted to the wall and can also be easily removed and it can be laid flat to do the actual painting. The cons are duribility and covering the joints. Has anyone ever tried anything like this?
Matthyro
Will always be re-membered
Dec 28, 2000
4,550
Georgetown, Ontario,Canada
I have and you need some good frame work to hold it in place because without it the card tends to warp. My preference now is to use 1/8th masonite as it can be curved for the corners too.
spitfire
3,448
Toronto, Canada
www.parkdaleyard.com
You can also use thin flexible plastic sheet from a sign supply shop. Don't buy from your LHS or you'll pay too much since they deal in smaller sizes. I used masonite for my backdrop, but it was full sheets, 4x8 and at that size it barely flexed at all - certainly not enough. So now, I have square corners, because I just found out about the plastic idea after I'd done the masonite. :cry: :cry:
Val
ezdays
Out AZ way
Feb 3, 2003
6,339
Arizona
bigbluetrains.com
Just got a great idea on this. Wait until the next election comes. Every street corner in town will be plastered with signs, some small, but many pretty big, 2' x 4' or even larger. Some are cardboard, but many are signboard and they all seem to stay stiff even after a rain. Wait until the morning after the election and help yourself, don't do it before then or you could wind up in the pokey since that it against the laws in most places. You will be doing them and the enviroment a favor. And the price is right. :thumb: :thumb:
Unlike Val, I haven't started my backdrop yet, but I think I'm going to wait, There's a local election coming up soon. :wave: :wave:
seanm
358
Sunny CA
www.pegnsean.net
I guess Masonite in full sheets won't bend enough, but I ripped mine into 16" strips and it bends REAL easy! I even have one place that needed an S curve and it worked. I used joint compound and some joints are better then others, but they are mostly hidden after painting.
F
Fred_M
I use a matte board which is already sky blue. It can be purchased at Hobby Lobby and is 2X heavier than poster board and bends corners easily. The straights will need need supported with slats. Fred
Pitchwife
Dreamer
Apr 23, 2001
1,728
Thanks for all of the input from everyone. :thumb: And here I thought that backdrops were a pretty cut-&-dried aspect of the hobby. :rolleyes: Glad to know that there are so many variations to choose from. Now to pick the one that is right for me. :D :D :D
SAL Comet
409
N.W. Georgia
I don't think anything is cut & dry, there seems to be a half dozen ways to do everything.
Sir_Prize
826
Port Charlotte,Florida
Here's mine...
I'm going to use clear lexan, the thin sheets. That way I can put images of buildings on the
front and back to give them depth. on the back I can "haze" things to make the buildings
seem even futher back (or smoggy like a city is). I a couple other "magic" things.
seanm
358
Sunny CA
www.pegnsean.net
Lexan? Sure don;t think I could aford it around my Layout! Maybe for one "module" or something.
I think I saw an article about someone using aluminum flashing in rolls. Looked interesting but I started to think about the cuts I would get from trying to handle 25' of 14" wide material with that sharp an edge. eeeeeouch!!!
Blake
446
Northern New Jersey
www.BlakeDTatar.com
Here's another one (just what you needed, right?). Styrene. A buddy of mine used 1/8" sheets of styrene and it worked out very well. He got it from a plastic supply place and it wasn't all that expensive. He said it was very flexible yet strong.
Pitchwife
Dreamer
Apr 23, 2001
1,728
Sir_Prize said:
Here's mine...
One thing I've found that produced good results as far as obtaining low cost plexiglass was a visit to my local glass store. I was able to procure a couple of pieces of plexiglass of varying thicknesses and dimensions by asking them if I could go through their trash bins. I picked up two nice pieces, one was 1/16" thick approximately 7"X54" and another piece 1/8th" thick 10"X18". The thin one will front the flashing where the tracks will be percariously close to the edge, and the other will make a nice layout point control panel. The best part was the price. Since they were "trash" I got them for FREE! Definately worth looking into. :thumb: :thumb: :D :D
jetrock
894
I bought some .020" styrene sheets from a local plastic supplier--40"x72" sheets--for $3 each. The price per foot is even cheaper for 4'x8' sheets. Thicker might be better for a backdrop--.040 maybe--but with less flexibility. A lot cheaper than buying sheet styrene at the hobby shop!
ezdays
Out AZ way
Feb 3, 2003
6,339
Arizona
bigbluetrains.com
It's a fact that Plexiglass (acrylic) is about a third the cost of Lexan, but it is more prone to cracking and not as easy to drill. One good source for cuttoffs, like Clark said, is glass shops or any plastic fabricator. We used a lot of acrylic when we had our business, and I always had pieces that were too small or an odd shape and weren't worth using. Some dealers will sell you these maybe by the pound, others will just give it away.
Another thing to consider is ABS sheets. Like styrene, it is very fexible and soft enough to drill or cut, but ridgid enough to stand up. It comes in a variety of colors and most have a texture on one or both sides. And it's cheap, about half the cost of acrylic.
seanm
358
Sunny CA
www.pegnsean.net
But if you need to have a backdrop that is 8 feet long or more, how do you deal with the seam if you are using plexi or plastic. With masonite or even drywall, mud and sanding works. I suppose you could use plastic filler putty or something.
jetrock
894
Actually, mud and sanding works fine for plastic too! It's how I hide seams in my styrene streets. The only trick to it is that instead of using sandpaper, smooth the dry mud using a damp sponge.
ezdays
Out AZ way
Feb 3, 2003
6,339
Arizona
bigbluetrains.com
That depends on the type of plastic. I'm not sure how well drywall mud would work on plastic over the long haul. I would think it wouldn't adhear that well and eventually crack. I haven't tried it so I can't say for sure, but I've worked around plastic long enough to wonder.
I doubt that you can get a seamless look no matter what you did, but there are many good glues that work well. You can get exopy in clear and different colors now days that would work on most any kind of plastic. You can use the same glue that you put model structures together to glue acrylics and styrene and for PVC or ABS, well there is both black and clear cement. Sanding a buffing will smooth things out, but let's face it, any seam doesn't have to be perfectly smooth, it will get painted over anyway so if it's a bit rough, who's gunna notice?
