Please help idling high
Discussion in 'RC Offroad Forum' started by Bloobert28, Jan 28, 2005.
Thread Status:
  1. Bloobert28
    Bloobert28 Member
    my engine idles really high with the controller throttle adjuster all the way down. should i tune it or is there a way to lower the idle on the engine. Please help
  2. dj6666969
    dj6666969 Active Member
    underneath the card there is a small screw that should have a spring on it for tension, not on the side where the throttle is up right underneath where you put the air filter on, this is the idle air control screw. By turning this the idle will go up or down, u want it to go down so I belive you screw it in to do that, or possible the other way just try it once and see, youll be able to tell if the opening in the carb gets alittle bigger or smaller, if it goes smaller the idle will be less and vise versa
  3. Bloobert28
    Bloobert28 Member
    thanks i'll try that
  4. Bloobert28
    Bloobert28 Member
    i just tried to adjust the needles what should the low end be set at for the winter. when ever i try to make it idle and sit there it died. when i run there is a good amount of smoke comming out.
  5. dj6666969
    it sounds as if it is rich
  6. badone
    badone Member
    yep sounmds rich which truck/car is it? and what engine??
  7. Bloobert28
    Bloobert28 Member
    the nitro envader st os .18
  8. Bloobert28
    Bloobert28 Member
    my low end screw is pretty far in. i think it might be too lean
  9. dj6666969
    if it is lean then there won't be to much smoke because the engins is burning less fuel so I think it might be rich
  10. Bloobert28
    Bloobert28 Member
    for low end tuning how long should the engine run if you squeeze the fuel line? thanks
  11. dj6666969
    the squeeze testI belive is for the high speed needle
  12. xerox
    xerox Member
    if you want to just bash your truck and have fun do what i did to my mt2
    first put then low end flush with the carb then when you have it set let it idel if it dies right away that means that you srewed in your idel control srew to much and you should lousen it but rember make the low end flush with the carb then when you get use to it and want to get more low end then screw it in a bit and you should see a difference
  13. Bloobert28
    Bloobert28 Member
  14. Bloobert28
    Bloobert28 Member
    thanks guys i just tried it and it works great
  15. dj6666969
    Your Welcome!
Thread Status:
