Pl300 ??????
Discussion in 'Tips & Tricks' started by cpNscale, Feb 16, 2007.
  1. cpNscale
    cpNscale Member
    Does anyone have any tricks on how to keep a tube of PL300 from drting out between uses.I have the large tubes and only need a little bit at a time.So when i go back to use it the nozzle is clogged and dry.I have tried wraping the nozzle with plastic wrap and a rubber band,but still think i may have wasted a half tube.Any thoughts would be great.
  2. Squidbait
    You could try cleaning the nozzle out with a nail, and then you'd just have a small plug where you punctured the foil in the tube - that should pop out easily enough if it hardens.
