Piston/sleeve
Discussion in 'RC Offroad Forum' started by digdug72, Jan 19, 2005.
Thread Status:
  1. digdug72
    digdug72 Member
    does anyone have an idea to remove the sleeve without vise-grips?
  2. car_nut
    car_nut New Member
    use the big end of a wire-tie and stick it in a port and pull it out
  3. ericmcgehee
    ericmcgehee Member
    or you can pull the back plate off, and push it up with your finger. or hey stick a screwdriver in there like you were prying on it and pull it out.. oh did you mean with out damage.
  4. digdug72
    digdug72 Member
    thanks guys for the info!
  5. rockn82
    rockn82 Marx Brother
    Put the engine in the oven at 350deg. Make sure you take off any part that is plastic or rubber. Take it out of the oven in about 15min and the sleeve should come out without too much of a fuss.
  6. tnx
    tnx Member
    dont forget gloves :D
  7. ericmcgehee
    ericmcgehee Member
    actually, mine always came out pretty easy. if you take the head off, and turn the crank, mine always pushed the piston up enough to grab it by hand and pull out. but i guess that wont work if it is wore out.
  8. digdug72
    digdug72 Member
    another question guys, just to be sure, an engine rebuild is just piston and sleeve correct?
  9. yes and bearings sometimes and if you take the back plate off and push it up with the end of a tooth brush .. and the piston should slide out
Thread Status:
