Photo Fun 5-23-08
Discussion in 'Photos & Videos' started by spankybird, May 23, 2008.
  1. Biased turkey
    Biased turkey Active Member
    I forgot, congrats for your purchase shaygetz, it is very impressive. I hope it runs well.
  2. jeffrey-wimberl
    jeffrey-wimberl Active Member
    Good idea Ralph. Now I know what to do with those old resistors I have laying around.
    I've been doing some work on the park today. The glue is still wet.
  3. shaygetz
    shaygetz Active Member
    Thanks, guys. It is an AHM/Rivarossi from about 1972, number 3 in my quest for all 4 articulateds that they put out. Still on the hunt for their 4-6-6-4 Challenger from about the same time:thumb:
    Nice work on that park Jeff...:thumb:
  4. tomkat13
    tomkat13 Member
    Layout update
    Not much new on the first section of the shelf layout. All the buildings on the mill siding must be raised up so the track side doors & docks match up to the boxcar doors. Also need to finish the truck-side dock, inside flooring, ect on the metal works building. The the Roads, parking lots, & other scenery after that.
    Any help or Ideas,.....Comments....And/ Or Questions feel free to ask. I'm always ready to learn more.
    My new layout, (#4), a bridge-line used by the CB&Q & MKT that takes place in Eastern Missouri, will connect the CB&Q near hi-way 79 at Old Monroe Mo., then west to Hawk Point Mo. then south along hi-way 47 across the old Wabash / Norfolk & Western RR line near Warrenton Mo. thru Missouri Wine Country to connect with MKT near hi-way 94 near Marthasville Mo. . Since this is "my" railroad most places will have the "flavor" of this area but may not be perfect to the prototype. Time will be pre Burlington Northern (1970).
    The things that will be different on this layout:
    #1 This will be a point to point RR built on Hollow-core doors along two walls, so it will be in sections.
    #2 It's going to be less track, no yard, no switch machines, open staging, & simple engine service area.
    #3 Just a few small towns with one or two sidings.
    #4 More open scenery between towns.
    #5 Interchange with RR on each end.
    #6 Keep everything simple so I can spend more time running then repairing!
  5. Pitchwife
    Pitchwife Dreamer
    I think that if you check out some of the electronic supply houses you might find some small enough. Look for 1/16 watt or smaller.
  6. jeffrey-wimberl
  7. brakie
    brakie Active Member
    Jrff,.I think I saw that boxcar yesterday on the NS with a tad more filth...Good job.
    Here's a look see at my 2 N Scale C&O RS1s.
  8. shaygetz
    I think it looks great and you're well on your way to your desired effect.:thumb:
    My one point to make would be not to put too much confidence in those doors unless they're of real good quality. I suggest supporting them at least every 24" as well as from front to back because they will sag over time. I've worked with them often over the years and I've actually seen them warp right in the jams, with no real explanation to be found.
  9. chessie4155
    chessie4155 Active Member
    Old Yard Tower:
  10. Biased turkey
    Nicely detailed and weathered yard tower chessie4155
  11. jeffrey-wimberl
    I've been busy on the centerpiece for the park and I must say it's a thing of beauty. The old K4 has been cleaned up and has had a cosmetic restoration. It doesn't look like the same locomotive.
  12. UP SD40-2
    UP SD40-2 Senior Member
    REAL NICE Jeffrey:thumb: , i was hoping you wouldn't make it a rust bucket sitting in the park, i see just very slight signs of weathering, just like most of the engines i have seen in parks, WELL DONE!:bravo: .
    [​IMG] - Deano
  13. jeffrey-wimberl
  14. CNWman
    CNWman CNW Fan
    Nice! I'd bury the ends of the track with ballast to blend the track in better and add a fence around the loco, but that's just me. Oh, by the way, are those good knuckle couplers on the loco? if this engine won't be pullin' no more, then you could just swap out some Athearn single peice molded couplers for the good ones. With enough work, the cheapo single mold couplers can look very much like real couplers, minus the spring of course:mrgreen:
  15. jbaakko
    jbaakko Active Member
    Heck, but some of the Gatzl dummy couplers offered by Sergent Engineering, they'll be to scale then.
    I recently finished decaling a CP Rail Bi-level rack. I used the included CP Rail decals from the Custom Rail kit, however, it came with a different style of "CP Rail" for the panel, so I had one printed, at the same time as I had the BNSF text & Brinks decals made. Looks great. Now to add lots of rust to the roof, and streaking down the sides...
  16. jeffrey-wimberl
    That's a future project. Those are old McHenry couplers.
  17. jeffrey-wimberl
  18. Pitchwife
    Pitchwife Dreamer
    These are all great pictures. And one of these days I'll have one to post. :cry: :cry:
    jeffrey, the weathering on your boxcar is superb. When I first looked at it I noticed the herald on the top right and thought that, considering the car's condition the last word only had three letters and was followed by an exclamation mark :oops:. But then I finally saw what it was. :mrgreen: :mrgreen:
  19. doctorwayne
    doctorwayne Active Member
    HEY FOLKS, just a reminder, this thread IS CLOSED to pictures...but COMMENTS are still WELCOME.
  20. toptrain1
    toptrain1 Member
    I think you can't have photo fun, if you can't have photos. It is like talking without words.
    frank toptrain
