Pepakura question
Discussion in 'Software' started by the4ce, Jul 25, 2008.
  1. the4ce
    the4ce Member
    I have some questions about Pepakura:
    1. How can I change the color of the edges? (I have tryed to change them but with no results)
    2. How can I hide some of the edges?
    Thats all for now...
  2. JT Fox
    JT Fox Member
    1. Configuration and then Color Configuration. In the window that open LMB the color you want to change and then it will open a second window with all the color options.
    2. 3DModelWindow and then Tick/Un-tick. This will show or hide all edges. I don't know if you can do that to specific edges.
    Hope this helps.
    Cheers JTF
  3. the4ce
    the4ce Member
    1. Well the Color Configuration works only for the 3D model. I want to color the edges for the 2D pattern.
    2. I can't the Tick/Un-tick option :( and I need to hide only some of the edges not all.
    Thank you anyway.
    I am still waiting for responses.
  4. Cláudio Dias
    Cláudio Dias Member
    These work on Pepakura 2.0
    Toggle "Set edge color" tool button or menu option "2DPatternWindow->Edit mode->Set edge color"
    Choose the edge type, the color or the erase button, then click on desired edge. You can also change multiples edges at once, by clicking and dragging the mouse to define an area containing desired edges.
    Hope it helps:thumb:
  5. the4ce
    the4ce Member
    It works!
    Thank you very much!:thumb:
