Pepakura Help
ElectricCraft1
3
I have downloaded designer and am having trouble with printing. I have a laser printer and would like to convert to a pdf so I can print. I have installed multiple pdf converters but when I convert, the pdf is blank. I also tried to export to bitmap, but the file needs to be unlocked with a password to do this, and I don't have the password for the files. Any ideas?
papermodeller
2
Your story is a bit confusing because I think like a lot of people you are mixing up the password for a locked PDO file with the registration key that you need to buy to get the full features of Pepakura DESIGNER, but they are two very different things.
But for printing, it doesn't even matter if the file is locked or if you don't have the full version of Pepakura Designer. And you don't have to convert it to a PDF file to print it.
You can use an unregistered version of Pepakura Designer to print a PDO file as long as the designer didn't lock it (it doesn't have a password) for a bit more possibilities (if you want to change the way it was cut or change the flaps a bit).
You simply open the PDO file, and click print in the file menu like you would normally do. That's all, and you can even use the print button if your Pepakura Designer is unregistered.
If the file is locked, you simply have to use the Pepakura Viewer, it is totally free and can even open and print locked PDO files (you just can't edit them, because it is only a viewer.
I don't know about your PDF converter problems if you still really want to go that way, because all you should have to do is install it, and then before you print, instead of your regular printer select your PDF printer, and then when you click print, it should ask you to save the PDF somewhere. Is there anything in the print preview or is it also blank? If the PDO doesn't have textures but is just white, make sure you didn't disable the lines and flaps.
ElectricCraft1
3
Thank you for answering...I do have the settings like you say, and it does get sent to my printer, but I am still getting a blank page even though the preview is not blank. I also changed to vector print and still get nothing on output of the printer.
