Pepakura Designer High Res. malfunctioning
Discussion in 'Software' started by paperPino, Feb 5, 2012.
  1. paperPino
    paperPino New Member
    After a lot of work without any problem, now I am not able to print some files. The problem is the same both for Pepakura Designer High. Res. and for Pepakura Viewer for CraftRobo.
    Different files (having the same size: about 430 Mb), generated from different parts of the same metasequoia model, behave differently: some can be printed, some others cannot, causing an unexpected escape from the program.
    OS: Windows 7
    Printers: Epson Stylus DX4850, HP OfficeJet 7500A Wide Format
    Software: Metasequoia 2.4.13, Pepakura Designer High Res. 3.0.7a, Pepakura Viewer 3 for CraftRobo 3.0.3a
    Thanks for your help!
  2. Zathros
    Zathros Guest
    I can't help you but just offer this post to bump the thread up so more may see it.
  3. paperPino
  4. ThunderChild
    ThunderChild Active Member
    The problem lies with your original model mesh. Check that your faces(polygons) are not inverted, and that the model is in fact solid. I had pepa crash on me a few times with a model. I eventually figured out that I had two unmerged vetices on top of each other that was suppose to be one vertex. Pepa doesn't always know what to do with a polygon that has more than 4 corners either.
