Penn Central in the Pink
TomPM
Another Fried Egg Fan
Oct 15, 2002
3,335
Drexel Hill, PA
www.trainweb.org
I had a request to see the grain covered hoppers so here they are:
Atlas PS-2 Covered hopper –Lehigh & New England
Atlas RS-11 – Penn Central
Athearn RTR Covered hopper - Klemme
TomPM
Oct 15, 2002
3,335
Drexel Hill, PA
www.trainweb.org
MDC Undecorated Covered hopper – Custom Painted – Ralston-Jefferson
Athearn/Walthers Covered hopper – Albert City
MDC Covered hopper - Klemme
MDC Covered hopper - Farnhamville
eightyeightfan1
Now I'm AMP'd
Torrington, Ct.
Nice work Tom.Always like the "railfan" shots.
Must've been a little bit after the merger. Penn Central paint shop hadn't quite gotten to that New York Central car yet....
UP SD40-2
2,709
GREAT SHOTS Tom!!:thumb: :D i look forward to YOUR "run by" EVERY weekend:thumb: . BTW, the rust on that PC hopper is slap AWESOME! THANKS!:D -Deano
LoudMusic
620
So when you take railfan pictures of your own railroads do you stage everything or, using this group of pictures as an example, is the train actually rolling by and you're snapping a bunch of pictures?
doctorwayne
3,516
Canada, eh?
I've found that it's best to stage the shots. Those working on small, photo dioramas probably have no choice in this regard, as there might not be room for the entire train. Staging allows you to check composition, compare exposures and generally, show more detail. Here's a "pan" shot that I did in order to impart the feeling of speed. I can assure you, the loco wasn't really moving all that fast: perhaps 10 or 15 smph at most. I always shoot with the camera either on a tripod, or sitting directly on the layout.
Wayne
TomPM
Oct 15, 2002
3,335
Drexel Hill, PA
www.trainweb.org
Thanks folks!
They are staged. Due to the speed of the trains it would be impossible to do a run-by as Doctorwayne showed in his post. Many times I do use the locomotives to position the shot. I basically have a mark that I have to pull the car to get it in the shot. It can become a mini-specialized operating session.
