Peco or Atlas?
Discussion in 'FAQs' started by brucemac11, Jan 22, 2006.
  1. brucemac11
    brucemac11 New Member
    After nearly 30 years away from this obsession I'm dreaming of finding the time to build my N scale layout. Not that it pertains to the question, but the time period is the transition from steam to diesel in some fictional part of the US. Here's my first question: Peco or Atlas for track/turnouts? Is one more reliable than the other? I'm going to use code 80, rather than change all the older trucks. I'll pay attention to the group wisdom. Thanks
  2. 60103
    I like Peco, but I'm in HO.
    Peco's "code 55" is an odd duck -- looks like code 55 outside the rails, but goes down to code 80 depth in the middle. There's a picture of it here, somewhere...
  3. ironmule2004
    ironmule2004 New Member
    Atlas or Micro Engineering-Which one looks more realistic? I see that the M-E goes down to code 40, is this ok for most N-scale cars?
  4. jcoop1
    jcoop1 Member
    I love the looks of Atlas C55, Not sure of the C80.
    On my On30 layout I am using a combination of Atlas Flextrack and Peco Switches and On30 (crazy track)
    To me the Peco is rock solid, but the looks where not as good as the Atlas. That is what it came down to me.
    Good luck
  5. engineshop
    engineshop Member
    I have Peco switches since they have a spring. There is no chance that a switch only moves halfway.
    Pecos will not work if you plan to use switching motors like Tortoise slow switching motors but they are great if you switch by hand or with solenoid switching motors.
    I also use Peco 80 tracks since they have "cement ties", which was a bigger concern than the "European spacing" on the Peco ties.
  6. brucemac11
    Thanks, Roland for the info. I was planning on using Peco since I have some left from years ago. I just purchased two Tortise machines because they seem to be what most folks prefer, maybe they're not using Peco turnouts. I like the idea of a slow moving switch but is that possible with Peco and another type switch motor? Maybe it all boils down to nothing in the long run; I'm trying to put together the pieces that will bring fewer problems in the long run.
  7. 60103
    In HO, I took the springs out of a pair of Peco turnouts to use Tortoises. (I've had other ones where the springs just fell out after 20 years.) Otherwise, the points snap over when the motor finishes its work. And if you don'r adjust the Tortoise properly, they may not move at all.
