Peco N-scale Double Crossover DCC Wiring
Discussion in 'DCC & Electronics' started by codeman708, Jan 3, 2005.
  1. codeman708
    codeman708 New Member
    I am wondering how to wire a peco double crossover for dcc. I have read that there are a couple different ways. One of the ways I have read, is that you should use a reversing loop module, so that all the switchs don't have to be thrown at the same time. I have also read that you should use switch machines so that all the switchs get thrown at the same time. I am wondering if there is any easier way to wire it and if there isn't would you recommened going with the reversing loop module. Thanks for the help, Cody.
  2. 60103
    There is a very good site called Loy's Toys which has all the information you need about wiring for DCC. (link goes directly to the crossover.)
    The wiring is independant of how many switches you throw. There are ways to wire the crossing frogs through the switch machines, but that's more complicated.
