Parabolic curves
Discussion in 'HO Scale Model Trains' started by NBS2005, Feb 9, 2007.
  1. NBS2005
    NBS2005 New Member
    Does anyone use these for their layout? The idea is that the transition from increasingly tighter radius curve to a minimum at apex, then opening back up again gives better operation and is more prototypical. Any one doing this?
    Also, how many HO loco's can the PowerCab run in stock form (without the booster)? Figure newer Atlas loco's.
  2. Santa Fe Jack
    Santa Fe Jack Member
    They're not mathematically parabolas, but I have transitional curves on my layout. I am doing the gradual curve transtition "by eye" with flex track.
  3. Torpedo
    Torpedo Member
    They are called transition curves or spiral easements, more commonly just easements. I have an old track engineering manual. I think it has the formula for calculating one in it.
    As mentioned, they are not parabolas, but in some cases are something called a cubic parabola.
    Edit: Here is a link to a PDF that talks about track easements, among other things:
  4. Ironhead
    Ironhead New Member
    I work easement into my curves, and wow, what a difference. It takes the edge off the tighter radius for sure.
  5. cidchase
    cidchase Active Member
    What I like best about using the easements is that the engines and rolling stock ease out of the curve onto the straight track. Without the easement, they're on the curve, then Wham! they're straightened out. It operates much more realistically with the transitions.:thumb:
  6. Glen Haasdyk
    Glen Haasdyk Active Member
    I've done easments on my visible curves. operation looks alot more smooth that way. Mostly I added a couple inches to where the curve would begin and 'eye-ball' the easement in.
