papercraft Borg Tactical Cube
Discussion in 'Science Fiction & Fantasy' started by Arbiter Bri, Jun 10, 2013.
  1. Arbiter Bri
    Arbiter Bri novice designer
    This borg vessel only appeared in a few episodes of voyager. many of the models i've seen are similar in design to mine, except one EXTREMELY detailed one, which is big, and the armor is actually 'built' off of the hull. this pdf contains the 'shell' and the cube itself, you can choose which model to build.
    build pics to come soon.
  2. dnalor
    dnalor Active Member
    Do you going to layer this?
    With a little blue or was it green led in the middle? that would be fun
  3. Revell-Fan
    Revell-Fan Co-Administrator Administrator
    The texture looks really good! Thank you for sharing! :thumb:
  4. tjbmurph
    tjbmurph Member
    Will have to give this a try! Thank you for sharing :)
