PAM, "Wet Water" what to use ???
Discussion in 'FAQs' started by Climax1880, Feb 20, 2004.
  1. Climax1880
    Climax1880 Member
    Here's a subject that I thought belonged here in the Tech Section. In making rock castings, what's the best method to treat the rubber molds before filling with plaster? I've heard of spraying them with PAM or "wet water" and all kinds of things. Since I am now starting with some rock castings I need some feedback. (Haven't done this before!!!)
    Thanks for the advice
  2. pttom
    pttom Member
    I just spray mine with water.
  3. shaygetz
    shaygetz Active Member
    We don't use anything at the club. Spray the base with water and apply the mold after it has set but not before it has hardened. It will conform to the base better. As for hardened ones, we just peel them out, then apply them with a stiff plaster "buttered" onto the base.
  4. philip
    philip Guest
  5. Matthyro
    Matthyro Will always be re-membered
    I have used Pam JR and it works very well.
  6. Climax1880
    Climax1880 Member
    PAM, Wet Water etc.
    Thanks for your help guys. Hey Philip, thanks for the line to CC Crow. I busily downloaded all his clinics to a disc :D :D :D
    Have a great day all
  7. Fred_M
    Fred_M Guest
    Plaster into rubber molds need nothing to release. Wet water helps to eliminate air bubbles and allows the plaster to flow into small details if you are mixing it on the thick side. Pam I noticed will leave a residue on the castings that effect how the plaster absorbs water based washes, esp. if sprayed heavy. And if you use too much PAM it makes the casting real rough and pitted, which can be good if that's what you want. I just use 409, fantastic, or dollar store spray cleaner for wet water anymore. It's handy and I keep several bottles around so it's also easier to find than the wet water bottle.:D Isn't wet water a funny name? Ever see dry water? How about condensed water, just add water to make more water. How about a dry lake bed? If it's dry for 100,000 years I don't think it's a lake anymore. FRED
