Paint thinner
Discussion in 'Getting Started' started by Chanda, Oct 3, 2006.
  1. Chanda
    Chanda New Member
    Can isopropyl alcohol be used as a paint thinner for Floquil paint ? I'm getting tired of paying $ 8 plus for a can of paint thinner.
  2. Russ Bellinis
    Russ Bellinis Active Member
    Only Floquil poly scale. The regular floquil is laquer. I would use floquil thinner to thin the paint, but there is no reason not to buy a gallon of the cheaper hardware store laquer thinner to use for cleanup.
  3. shaygetz
    shaygetz Active Member
    Plain old laquer thinner like Russ said...'bout $1.29 a quart here. Lasts me forever.
  4. doctorwayne
    doctorwayne Active Member
    As noted, lacquer thinner works just as well as Diosol, and is a lot cheaper. I buy it by the gallon, as it's also excellent for use as a cement for styrene.
  5. Jim Krause
    Jim Krause Active Member
    Thanks folks. I learned something by just reading this thread.
  6. ejen34
    ejen34 Member
    What is the difference chemically between laquer thinner and paint thinner (acetone) ? Paint thinner runs me 5.24 a quart.
  7. brakie
    brakie Active Member
    This is one area I don't recommend cutting corners to save a buck or two.Use the cheaper thiner for clean up but,stay with Dio-Sol for thinning the paint.The reason is many to include the cheaper thinner attacking the plastic.
  8. doctorwayne
    Floquil paint will, itself, attack styrene if brushed on or sprayed too heavily. I've been using lacquer thinner in place of Diosol for over 30 years, including a long stint of custom painting.
    Ejen34, I checked my supply of thinners in order to answer your question. Among many other uses, acetone can be used to thin paint, varnish, and lacquer. It will also dissolve epoxy paints and glues. The sole listed ingredient is acetone. Lacquer thinner's express use is thinning lacquer-based paints. The listed ingredients are: toluene, methyl ethyl ketone, methanol, and acetone.
    While it would appear that acetone is a suitable thinner Floquil paints, I've not used it as such, as I find the odour much more objectionable. When using either of these products, it is very important to wear a proper two-stage respirator, and to provide adequate ventilation. I use a spray booth vented to the outside for most painting, although large items, such as bridges or large buildings, are painted outside.
    While I'm uncertain about the properties of isopropol alcohol, methyl hydrate (denatured alcohol), which I use to strip paint from many plastics, and also as a thinner for some water-based paints, is also a very dangerous chemical, and should be used with the precautions noted above. In addition, methyl hydrate is readily absorbed through the skin by contact, and through the eyes, as vapour.
  9. ezdays
    ezdays Out AZ way
    Paint thinner is not acetone. Paint thinner is more oily and less volatile than either acetone or laquer thinner. Paint thinner is good for reducing and cleaning up enamel paint and is a lot safer to use than the other two, plus it's a lot cheaper. I used laquer thinner in large quantities to clean screenprinting screens and it did a number on my sinuses over the years, so I don't recommend using it in other than a well ventalated area. Acetone is a good for general-purpose cleanup and for taking paint off of stuff, but again, use venalation when using it.
    Me, I use mostly acrlylic paints and either water or isopropyl alchohol for thinning and cleanup. You can use alchohol for removing acrlyic paints and it's a lot easier on the plastic than either laquer thinner or acetone.
  10. Russ Bellinis
    If you use paint thinner (usually it is mineral spirits) it is intended to thin enamel paints not laquers. As soon as you pour it into the laquer, it will "shock" the paint and suddenly your container is filler with what looks like granules of colored saw dust. Use laquer thinners to thin laquer paint. Use mineral spirits to thin enamel paint, and use either denatured alcohol or distilled water to thin water based acryllic paint. I know some people have used isopropyl alcohol to thin acryllics, but I tried it once and the paint shocked. I don't remember what type or brand the paint was and I used 70% not 90%, but I've never used isopropyl alcohol with paint since.
  11. brakie
    Guys as a safety warning acetone should be used with lots of ventilation and respirator..It is very dangerous to breath.
  12. 60103
    Did Floquil change the composition of its paint and of DioSol in the last 20 years?
  13. doctorwayne
    They may have, but the only change I saw was smaller bottles for bigger money.:rolleyes: Maybe you're thinking of Scalecoat, which came out with Scalecoat II.
  14. Russ Bellinis
    I don't think so. Use the same precautions Brakie mentioned for acetone with laquer thinners as well.
