P.1214 Griffon by Rafa
Discussion in 'Aircraft & Aviation' started by rafaelgonzalez65, Jul 1, 2007.
  1. rafaelgonzalez65
    rafaelgonzalez65 New Member
    Hola amigos!!!
    Here is my scratchbuilt representation of the BAe-Hawker P.1214 VSTOL Fighter project. I built it from 3-views, dissected in photoeditor and resized in Powerpoint to match something like 1/72, if I remember correctly.
    The planform and forward/upper fuselage and canopy are cardboard (Cardboard, Yum!!!), the lower fuselage (deformed cardboard F-16) is plastic and card, the sponsons and vertical canted fins are plastic.
    The forward vectoring nozzles are cast in white glue from a harrier's original, and the humps and lumps in the belly and sponsons are plastic fuel tanks from other scale models.
    The rear nozzle swivels up and down. It is made out of a cable tip isolator.
    All was then coated in heavy marine varnish, let dry, and a coat of plastic finish for wood floors, then sealed and painted.
    I hope you enjoy it as much as I enjoyed inventing and building it.
    Started life like this.....
    Gaaaaping mouth, say "AAAAAHHHH!!"
    Right side
    Don't try to get on my 6 o'clock!!
    See? I can out-turn you!!!
    And I can turn tighter than that!!!
    Nobody can beat me in the vertical!!!
    Relaxed again....
    I do "da Cobra".... tra-la-la-la-la!!!
    And I can haul some serious Iron, fa' sure!!!
    What, Ya lookin' at me?!?!?
  2. chapuzas100
    chapuzas100 Member
    Great work, is fantastic.
    I animate and continues showing your creations.
    Un saludo
