Ordering from GPM.PL
Discussion in 'General Card Modeling' started by Texman, Jan 12, 2007.
  1. Texman
    Texman Guest
    I am about to take a major leap of faith and order from www.gpm.pl.
    Has anyone ordered from here before? How did it go? Was the service/delivery times reasonable? Would you do it again? Looking
    to spend what is only a moderate amount, but want to know something
    more about them.
  2. Bengt F
    Bengt F Active Member
    Jump to it, Tex,
    I haven´t ordered directly from GPM - I mostly order from http://www.moduni.de/ or Herr Slawomir Wojcik at http://www.kartonmodellbau.de/.
    I have ordered a bunch of models from Betexa.cz in the Czech Republic, though, and it went like clockwork.
    Their link, if you´d like to take a look, is: http://www.betexa.cz/eng/btx-ramy.html
    However, I can really recommend that you get in contact with the very well-stocked Mr Wojcik in Germany - he has many GPM models, and, at very reasonable prices. The delivery is sometimes a little bit on the slow side, though. It might be good to be prepared for this but I think it´s worth it.
    Good luck,
    Bengt :D
    PS. I´ll post another link below, with the August 2006 card model catalogue from Kartonmodellbau.de!
  3. Bengt F
    Kartonmodellbau.de Catalogue, August 2006
    Hi again, Ray,
    Here is the pdf of the catalogue, as promised:
    Bengt :D
  4. rlwhitt
    rlwhitt Active Member
    Hi Bengt!
    I tried saving the attached PDF and it came out to only 198K and Acrobat says it's corrupted. Can you verify it opens on your end?
  5. Texman
    Texman Guest
    Hey Rick,
    Just tried it and it works on my end.
    Thanks Bengt
  6. Bengt F
    Yes, Rick,
    My original pdf works fine here too.
    However, the second link I gave you was wrong - it should be .com, not .de.
    Here´s the correct link to Slawomir´s web site: http://www.kartonmodellbau.com/
    Here you can also download a more up-to-date catalogue and see a lot of nice photos of customer-built models.
    All the best,
    Bengt :D
