Opinions needed
Discussion in 'RC Drifting and Setup' started by theRumblePhish, Oct 13, 2006.
  1. theRumblePhish
    theRumblePhish New Member
    So new to this RC drifting and considering buying buddys rc and want to see if its driftable.
    StreetForce GP
    Wheelbase: 10.24 inches (260 mm)
    Weight: 3.15 Lbs. (1429 g)
    Chassis Length: 13.78 inches (350 mm)
    Chassis Width: 7.48 inches (190 mm)
    Chassis Height: 4.72 inches (120 mm)
    Body Length: 16.85 inches (428 mm)
    Body Width: 7.48 inches (190 mm)
    Body Height: 4.72 inches (120 mm)
    Ground Clearance: .43 inches (11 mm)
    -Velocity .15 DuraTrax Engine
    -Finned Heat-Sink Engine Mount dissipates heat for cooler running.
    -75cc Flip-Top, Fuel Tank with Primer Button.
    -hex Center Turnbuckles at all four camber rods and both tie rods. Allows -quick adjustments without disassembly.
    -Futaba 2-Channel Pistol Grip Radio System is Pre-Installed into car.
    -Ball bearing-supported crankshaft.
    And wanted maybe buying HPI Stage D kit to fit it if possible.
    Sorry for any stupid questions.
