Open Bmann 4-8-4 J freight version tender ?
Discussion in 'HO Scale Model Trains' started by Snapper, Aug 10, 2007.
  1. Snapper
    Snapper New Member
    Hi all,
    How to open the Bachmann 4-8-4 tender (J class from N&W freight version item 82105) ?
    After remove the central "screw", the box don't seperate from the base...
    Thanks for your answers ;)
    Here scan and photo :
    [​IMG] [​IMG]
  2. Nomad
    Nomad Active Member
    Looking at the bottom of the tender I see notches in the base of the tender at the sides. I see at least two on each side. There are usally tabs there. Carefully use a screwdriver to pry the tender side out slightly to release the tab at the same time pulling up on the bottom of the tender. Be very careful because you could crack the tender side.
