Old Con-Cor (Kato) n scale Alco PA-1 part
Discussion in 'N / Z Scale Model Trains' started by salpiner, Jan 28, 2008.
  1. salpiner
    salpiner New Member
    Loco is about 25 years old. I am in need of a drive gear for one of the trucks. The gear itself has about 30 "points" on it. Anyone have an old exploded parts diagram that could help with a part number? Or somewhere I might be able to find the part? Thanks.
  2. blackwidowfan
    blackwidowfan New Member
    pa parts
    I may have the item you need. I'll have to dig for it.
  3. salpiner
    salpiner New Member
    Thank you very much for your reply. I was concerned that a part this old may be unattainable. I love this PA; it got my dad and me started in the hobby many years ago!
  4. Bones
    Bones Member
    Does any part of the model or original box say "Sekisui" on it?
    I am assuming this is a 'Con-Cor by Kato' PA, but just wanted to verify.
    If it is - Which gear do you need? The cup gear that engages the motor? One of the tower gears? One of the idler gears in the trucks?
    Which ever it is, I've got it. I can send it your way for a couple bucks. PM me if interested.
  5. blackwidowfan
    part number
    The spur gear is #0009-200012
    worm shaft set 0009-200011
    Hope this helps. I have a pa minus a motor that I keep for parts. I would suggest getting the parts from Bones..
  6. blackwidowfan
    pa motor
    Do you have any pa motors with the gears for sale?
    email me at fgroza@msn.com
  7. Bones
    Bones Member
    I may have one motor left. I'll check once the household is awake. I believe I removed it due to crumbling magnets, but I am not 100% positive.
    I feed off the 'broken' and "don't run too good" boxes at the LHSs. So, I go through a lot of parts.
