ok, tonight im going to build a layout.
Discussion in 'G / O / S Scale Model Trains' started by ozzy, Jan 20, 2008.
  1. ozzy
    ozzy Active Member
    ok, i been running trains!!!!!!
    its completely different then the plan i started with. and its just track on the wood bench work, went with one line, but it has more then one route to take and has inclines. i have some tweaking to do,,, before im 100% happy with it, but i need some more track pieces . i will take it up in a few weeks when i buy some grass mats. and i will then put foam under the track. and i would like to get a couple bridges.
    my main goal was to have running trains before friday, as i will have surgery then and i wanted to be able to run trains while im home 3 or 4 weeks healing.
  2. steamhead
    steamhead Active Member
    Ozzy...This is for sure some adventure..!!! And all the trials and tribulations others have gone through sure did get some chuckles....Hope everything works out OK with you and the CO....And hope your surgery goes OK..!! Keep us posted.
  3. Renovo PPR
    Renovo PPR Just a Farmer
    Hey best wishes on the surgery.
  4. ozzy
    ozzy Active Member
    oh ya, all the bench work was made out of scrap lumber, or leftover lumber from other home projects, only thing i had bought for it was screws.
  5. ozzy
    ozzy Active Member
    well my 1:48 Lionel husky stack car will not fit under my lionel elevated trusses , they are 5 1/2" tall,,,, if i just had a 1/4 inch more...lol
  6. Brutus
    Brutus Member
    Ozzy, sounds like you got a lot done dude. Can you make some little wood feet or spacers for under your trusses - that's what I did one time, just fyi.
    Good luck on your surgery Friday and keep us posted, okay?
  7. Geno
    Geno Member
    I use scrap pieces of 1/4", 3/8" and 1/2" MDF, srounged up for free from a cabinet shop- rip these on a table saw and you're good to go on shims.
    The Lionel Husky stacks are tall boys. Try running them through Lionel's Extension bridge (6-12772) on Fastrack- no joy there. I barely got the Husky Stack to fit with 027 tubular track- had to take the center reinforcing ribs out of the top of the bridge.
  8. I haven't been to his house yet but there is a gentleman that I have bought trains from a few times in york hes a proffesor at one of the collages up there any way he has 15 operating train layouts occupying about 2500 SQ Feet of his house. Next time up think I'll go and get some pics for you all.
  9. ozzy
    ozzy Active Member
    think i can get away with another extension tonight?......lmao
  10. scubadude
    scubadude Member
    Doo-it, Doo-it, Doo-it ! :twisted:
  11. gkcooper365
    gkcooper365 New Member Old S Scale
    Thanks for sharing
    I really enjoyed your story, and the great progress you have made. The boss helps me buy stuff for my layout, and is getting ready to paint some people for me. I am going to start a thread and share a little on my layout. Thanks for the push to get me contributing on this forum.
  12. Geno
    Geno Member
    How's your progress coming along? Have you made peace with your wife yet?
  13. ozzy
    ozzy Active Member
    peace?... yep,,, i can leave it up the way it is for now while im home recouping from surgery. then we will go into negotiation's on how i can add on.
  14. scubadude
    scubadude Member
    Hey Ozzy, glad you are home and hope your recovery goes well...now on to business.....I say you negotiate NOW, while Momma may have a little post-surgery sympathy! :twisted:
  15. ozzy
    ozzy Active Member
    here are some pics.
  16. ozzy
    ozzy Active Member
  17. ozzy
    ozzy Active Member
    even more
  18. ozzy
    ozzy Active Member
    the last of them.
  19. kfh227
    kfh227 Member
    Awesome pictures. That setup is looking good. Whenever I see layouts like that in O gauge I rethink my idea of the around the room setup.
  20. ozzy
    ozzy Active Member
    this layout has a loop, and then if i want it to it can be a loop to loop with both loops at the same end of the layout, one upper and one lower.
    the upper loop is a mix of 036 and 048 curves .
    i have plans to make changes to it already,,,,, when i get some more switches and other track pieces.
    right now i can run 2 different routes, but only one train at a time, i want to change it just a little bit to run 2 trains at a time and have a siding or two.. the 2 sidings i started out with are now the up and down grades of the upper loop.
