OK, now what has happened----
jr switch
204
northern Indiana
I have probabely used my Spectrum Decopod maybe 4 or 5 times since I got it. It's only about 2 or 3 months old. Sort of my favorite. Thought I'd exercise it a little tonight, put it on the track, checked all the wheels and gave it power--nothing. Checked for dirty wheels, dirty track, checked the cab to tender connections, everything looks ok. Last time I ran it ,it worked fine.
Put my EMD switch engine on the tracks, works normally. Other engines all work normally. I noticed, with the Decopod on the tracks, the diesel will hardly move at all with the controller turned all the way up. Sound like Iv'e got a major electrical short in the Decopod? Maybe the engine shorted out? Have any of you had this happen before?
Please give me some ideas, but I'm not sure I'm up to tearing this engine apart. Should I just send it to Bachmann?-------John R
shaygetz
3,612
www.freewebs.com
Check the wheelsets on your tender, one of them may have spun around 180 degrees, creating a dead short. The insulated side should be on the left.
jr switch
204
northern Indiana
Dave, I didn't check the light, but no motor hum at all. Can't be gears locked up, it's belt drive and I can move the driving wheels back and forth just a little due to the normal amount of play in the system when stopped.
Another thing is the complete drain of power to the other engine on the same track. The other engine wouldn't even run until I removed the Decopod, then it ran normally. I'm thinking there is a major short inside this engine.-------John
jr switch
204
northern Indiana
Shaygetz--How can I tell? The front and back of the truck sides look the same and the pick-ups are centered and go the the center of the axles. I don't see any side to side differences-----------John
radar
122
wichita , KS
One of the wheels of the axel should have like a plastic insert where the wheel joins the axel the other side won't
shaygetz
3,612
www.freewebs.com
Like Dave said, there should be an insulating barrier of some sort...usually a small plastic or nylon ring around one axle between the wheel and axle.
jr switch
204
northern Indiana
I checked to be sure truck was not turned around. There are small moulded in pins that assure trucks will not reverse. They can't get turned the wrong way. I also checked for broken wires, bent pins in connections, all ok. Wheels on tender were a little dirty, but not excessive.
Iv'e only had it a few months, but did not send warranty card in yet. Will Bachmann give me a problem or are they somewhat forgiving? Iv'e heard that they are real good about taking care of problems. -----John R
yellowlynn
741
Whitehouse, Tx USA
A fast way to check, for me, is turn it upside down and touch leads to the different wheels. If you can touch the leads to wheels on the same side, the wheels are backward. Just find which wheels to touch to make it run and take it from there.
Lynn
doctorwayne
3,516
Canada, eh?
On Bachmann Spectrum steam locos, the tender trucks pick up from opposite rails, so one truck should have the insulated wheels on one side, and the other truck the opposite side. I don't know which one should be which way though, as some of my Consolidations are the opposite of others. The loco also picks up from both rails, with the circuit board in the tender sorting things out. Also, make sure that the plugs between the loco and tender are both connected.
Wayne
jr switch
204
northern Indiana
Hey Wayne, I knew you were still out there somewhere! Iv'e put it back on the rails three times, to no avail. Checked the connections and the connector pins twice, this tender has pins to keep the trucks straight, I tried to reverse them and you can't, checked for a broken wire, all the wiring is intact.
All the other engines work fine so that eliminates track/controller. Tender wheels have been cleaned. Still won't run. What I did notice, is when this one is on the track, it sucks the juice away from another on the same track. Somehow, it's pulling a lot of amps.
I have all of the paperwork that came with it, the warr card etc., so I'll give Bachmann a call and get it to them. Thanks all, for the helpful suggestions--
It will be interesting to hear what they find-----John R
Hey John, why don't you check the resistance between the wheels from side to side with the loco off the tracks? Sounds like there is a short circuit across the rails, or a very low resistance. Unplug the tender connection and check again. If the resistance is appreciably higher then you have isolated the short to the tender. If not, then the short is likely in the locomotive. Something as simple as a small piece of metal or wire in the works could cause this, or a small screw adrift inside the shell. (try the shake test) Of course, your motor windings could also be melted! :D :D (probably not)
You should be able to localize the problem this way. Even if you don't have a meter, remove the tender and see if the other locos will run with this one on the tracks.
sidetracked
84
i bought a bachmann spectrum when I first got back into MRR, I didnt have it for an hour when the belt broke,,, might check it,, you couldnt hear any motor hum or anything on it either,,, when i got it apart the belt seems like it was really brittle, ,,,, I never sent my card in but call bachmann and they didnt have a belt in stock but took one off another loco and sent to me,,,,, ,,,,,,good luck,,,, ,,,, ,,,,,,,,,, ,,,,,,,,,, ,,,,,,,st
jr switch
204
northern Indiana
Again , Thanks guys, for the helpful suggestions, but I'm going to have Bachmann make it right. I checked everthing that you all thought of, short of taking it apart, and couldn't find the problem, so I'll let them fix it. I will post what was wrong so that we all have one more bit of HO steam engine know how ----thanks ------John R---
