vanda32547
Hi Ya'll,
I finally got my MRC Prodigy Advance DCC System last week :thumb: but understand I need to send it back to MRC for a slight power modification change since they under powered :curse: the unit ... but that's ok because I have not laid the track yet on my new layout.
I have been working on the benchwork (pix at http://www.the-gauge.com/showthread.php?t=10986) and am just about ready to lay some track. I'm using code 100 flextrack since I have alot of it and my Atlas snap switches are also code 100.
I have been reading alot that DCC people run feeder wires to every section of track? Does this mean zones or does it mean "every" section of track? Should I wire the turnouts seperately also?
I am planning on having 2 reversing loops (probably buy Tony's Train Exchange modules) and will order them one of these days. Does anyone use these and what is your feedback? I have read that these also require special wiring with insulators at both ends like a regular DC setup is that correct?
I also realize that I need decoders for each of my turnouts and need to order those as well. I am concidering the Lenz LS150 which controls 6 switch machines. Does anyone have this and how do you like them?
Sorry for all the questions but before I lay a stick of track I want to make sure I am doing it right. Thanks for any input and info you can provide.
Regards,
Regards,
