O.S. .15 CV-X NOT STARTING
Discussion in 'RC General & Getting Started' started by mxmx995, Mar 9, 2004.
Thread Status:
  1. mxmx995
    mxmx995 New Member
    Hey i just got my new o.s in trying 2 start it is giving me trouble i got the high speed needle 2 turns out from closed in when i try starting it won't start ,but when i hold the throttle open fully it starts to bobble then slowly comes to life then immediately shuts off before i can even take the glowplug off...........i need help???????????
  2. mastmec
    mastmec Member
    Pull off the fuel line and glow plug, pull the starter several times to clean it out. Check the glow plug, make sure it's bright orange. If your having to hold the trottle wide open, it's too rich or flooded or fouled plug. If you have a primer, prime till fuel reaches the carb and then once more, too much will flood the engine. Also try a heat gun or blow drier to warm up the engine a little first, then try to start it.
  3. Jshaff15
    Jshaff15 Member
    Sounds like the low end is very very rich if it wont even start and run long enough to get the glow plug off. just my $.02
Thread Status:
