Novak gt7 help asap!!!!!!!!
Discussion in 'RC Offroad Forum' started by ty007cars, Nov 4, 2004.
Thread Status:
  1. ty007cars
    ty007cars Member
    I need to know how to setup my gt7 to have breaks!! I didnt get a manualin a trade.... i cant download manuals off the internet because its to F@#king slow.....so please tell me how i can get brakes on my esc!
    TY
  2. monsterrcbuilder04
    well i hope this helps but im nto sure if its what you asre exactly looking for.lol
    The GT7 lets you set the minimum braking force for each
    of the 7 Throttle Programs––each Program stores its own value
    independently. The value for the minimum braking force is a
    percentage of full-brakes (transmitter’s throttle at full-brake position).
    The 7 available choices are 20, 30, 35, 40, 45, 50, & 55%.
    Brakes then range from selected value to 100% braking force.
    Selecting Minimum Brake %--TRANSMITTER ON
    With transmitter ON & GT7 connected to receiver and battery:
    1. TURN ON THE SPEED CONTROL’S POWER
    2. PRESS & HOLD SPEED CONTROL’S SET BUTTON
    With transmitter throttle at neutral, press and hold SET
    button on GT7 until all 4 LEDs turn on.
    3. PUSH TRANSMITTER THROTTLE TO FULL-BRAKES
    When the transmitter’s throttle is moved to the full-brake
    position while still pressing SET button on the GT7, only
    the blue status LED will remain on (2nd LED from top).
    4. RELEASE SPEED CONTROL’S SET BUTTON
    Blue status LED will flash. The number of times the LED
    flashes indicates the Minimum Brake selection (1 of 7).
    5. PRESS & RELEASE SET BUTTON TO CHANGE SELECTION
    Each press will change to the next consecutive Minimum
    Brake value. (After value #7, the sequence begins again at value #1)
    6. WAIT FOR SPEED CONTROL TO EXIT PROGRAMMING
    When SET button is not pressed for about 3 seconds, the
    selected Minimum Brake value is loaded into memory.
    The blue status LED will then flash a few times rapidly, then
    the status LEDs will come on, one at a time, scrolling from topto-
    bottom indicating that you are exiting programming. The
    red status LED will then turn on solid, indicating that the speed
    control is at neutral and ready to go.
    Selecting Minimum Brake %--WITHOUT TRANSMITTER
    With the transmitter power OFF (or input harness disconnected):
    Green and red status LEDs will both turn on solid
    indicating no input signal is being received.
    Continue to hold SET button on GT7 beyond the point
    when all 4 LEDs turn on, until only the blue status LED is on.
    3. RELEASE SPEED CONTROL’S SET BUTTON
    4. PRESS & RELEASE SET BUTTON TO SELECT PROGRAM
    Each press will change to the next consecutive Program.
    5. WAIT FOR SPEED CONTROL TO EXIT PROGRAMMING
    blue status LED flashes rapidly, the four status LEDs scroll
    from top-to-bottom, and ESC exits back to neutral.
    The GT7’S 7th Throttle Program can be customized to fine
    tune the speed control to feel just the way you like it.
    The 7th Throttle Program lets you tune the following items:
    • Drive Profile--1 of 5 Drive Profiles (each profile is comprised of
    Drive PWM Frequency, Minimum Drive %, & number of throttle steps
    for the transmitter’s forward/drive trigger throw).
    • Brake Profile--1 of 5 Brake Profiles (each Brake Profile is comprised
    of Brake PWM Frequency & number of braking steps for brake throw).
    • Braking Type--1 of 2 types of braking styles (STD.BRAKE--Novak’s
    Constant Force braking or DRAG BRAKE style braking).
    • Minimum Brake Percentage--1 of 7 settings from 20 to 55%.
  3. ty007cars
    ty007cars Member
    thanks dude!!!!!!!!!!!!!!!!!!
  4. monsterrcbuilder04
    lol it took me a minute to learn how to copy and paste from adobe reader but i ahd the time.lol. no problem. i have that esc but i dont have the manual and i havnt put it to use yet.
  5. ty007cars
    ty007cars Member
    lol, well this dose help but its confusing i keep doing it wrong,lol
  6. monsterrcbuilder04
    lol...it always does
  7. redheat
    redheat Member
    You should have some kinda brakes reguardless of what setting your at, follow Monsters thread and you should be okay , did you purchase your Gt7 new? RED
  8. ty007cars
    ty007cars Member
    no i got it in a trade but it is fairly new he said.....thee gt7 has no brakes at all it barely stops the buggy but it has relly good th response.
  9. redheat
    redheat Member
    well I would say that if you dont have brakes then the ESC is toast , can you program it for throttle setup? RED
  10. ty007cars
    ty007cars Member
    ya that stuff works, but i just dont know how to set it up.....Its confusing
  11. redheat
    redheat Member
    Well dont no what to tell you man other than follow the instruction that Monster posted or take it to your local hobbie shop and have them help you set it up , RED
  12. ty007cars
    ty007cars Member
    thanks man
Thread Status:
