NOBI's North American A-36
Discussion in 'Aircraft & Aviation' started by milenio3, Mar 8, 2007.
  1. milenio3
    milenio3 Active Member
    Let's go to the wheels.
    The model has parts to make the wheels from laminating the circles. I change this to just laminate them up to 3mm with heavy cardstock.
    The rest is the method I learned in this forum with the masters (won't mention them here fearing I miss one or two, but you all know who they are).
    First, glue the radial parts with the laminated paper.
    Then, sand the wheel turning it so you can have an even tire.
    Then paint black the wheel.
    I still have to enhance my wheel technique, though.
  2. Bowdenja
    Bowdenja Active Member
    I'm going to have to disagree on your wheel technique............. looks like you have it down to me!:grin: Those look very good to me.
    How well does the 3mm stock sand? Are you hand sanding, or using power tools (dremel)?
    The model is really looking pretty good, I like the added black piece to the moving surfaces. It really does give it that depth feel.
  3. milenio3
    John, in fact the 3mm paper laminate works good for me. I took to myself the Golden Bear tip on gluing two circles 1mm 1.5 mm each, so you can have either 2 or 3 mm, depending on the paper you are using at that moment, but use wood glue, not the usual glue. In this case, I used Testor's for wood (the tube is green-yellowish color); that way, the join is stronger, so after dry, you can sand it with no problems. Oh, and I don't have any tools, just sand it at hand. But definitively, a dremel will be much much better.
    Thanks for the comment.
  4. milenio3
    The landing gear complete...
    And now in its place under the wing.
  5. milenio3
    A little change for the propellers. They would look better if a piece of wire is placed inside each propeller. This achieves two purposes: a) a rounded look and b) an insert to the spinner.
  6. milenio3
    Now the plane is ready.
  7. milenio3
    Another view.
  8. BARX2
    BARX2 Member
    Looks great! Very good job.
  9. Ben Gal
    Ben Gal Member
    Fast build!! - looks great
  10. Rick Thomson
    Rick Thomson Member
    Not too shabby at all.
    I especially like the control surfaces hacks.
  11. Bowdenja
    Looks good Gerardo! I really do like the separate flaps, rudder and alerons. It really does make the model pop!
  12. Clashster
    Clashster Member
    Great job! Really made it come alive! Thanks for the updates!
  13. cgutzmer
    cgutzmer Guest
    Very nice build! thanks for sharing it with us. Oh and dont feel bad about the wheels - I think they are great! They turn out just like all mine do :)
  14. milenio3
    Thanks for all the comments, friends.
    And yes, this one was a two day construction over the weekend, just in time for the Free #2 contest.
    It was fun to build it. Thanks to Nobi and all of you
  15. eagleone
    eagleone Member
    What is the link to nobi's website?
  16. shoki2000
    shoki2000 Active Member
  17. sjsquirrel
    sjsquirrel Member
    Very nice build and very informative build thread Gerardo. I'll definitely be trying your technique for the rudder and ailerons on the next plane I build. Thanks for joining our little community here.
  18. Jim Krauzlis
    Jim Krauzlis Active Member
    Superb job, Gerardo!
    You made a great kit even greater!
