NJ International switch stands
Discussion in 'FAQs' started by warren danzenba, Oct 23, 2002.
  1. warren danzenba
    warren danzenba New Member
    Has anyone had success in attaching working NJ International Low Ramapo switchstands (Model 1914) to Atlas Custom Turnouts. It is easy to link them together, but when I throw the turnout, the distance that the linkage moves, doesn't turn the switch stand a full 90-degrees.
  2. Vic
    Vic Active Member
    Hi Warren, could you possibly post a picture of how the switch stand attaches? Are you using the switch stand in conjunction with an under-the-table switch machine and linkage? A friend of mine had the same problem...we finally hit on adding a 90 degree bellcrank to the linkage.
    If you are using the switch stand to throw the turnout manually possibly re-locating the attachment point on the turnout's throw bar would solve the problem.
    Know this isn't much help but maybe a starting point.
