Nitro problem
Discussion in 'RC Onroad Forum' started by crazycuteguy016, Aug 29, 2005.
Thread Status:
  1. ok i just got a nitro rs4 3 evo and i just broke the motor in.
    But now when i start ii its start up right away BUT when i pull the trigger slightly it cuts back off. wuts the problem thank u n adcance
  2. dj6666969
    dj6666969 Active Member
    try letting it run alittle while and also it could be to lean.
  3. digdug72
    digdug72 Member
    richen up the high and low needles a tad
  4. ok i tried that n it still keep cuttn off on me
  5. digdug72
    digdug72 Member
    check your idel screw, it might be a tad to low
  6. check for air leaks.
  7. digdug72
    digdug72 Member
    problem solved? Yeah, cracked / or small holes in fuel lines
Thread Status:
