Hello all,
I am new to model railroading and wanted to see if I could get some help on a few questions about curver radius... I own the Bachmann 2-8-0 Outside Frame Consolidation, I know that in the box it states the mininum curve radius to be 22 inches (I have read elsewhere that it can be as little as 18in.).
What I would like to know is:
1) when figuring the radius is it from the "center point" of curve to the -inside rail? -centerlinde(CL)? or -outside rail?
2) when Bachmann figured the minimum curver radius: does this mean the engine can take the curve at -low speed? medium speed? high speed?
I am working on my track plan and it seems to me that a 22" radius is pretty darn big(a 22" radius circle would take up almost a half a sheet of 4X8 plywood) so, How do you reach the back of the curve? with a lift out section(I would like to avoid this if possible)? I have an 8.5' X 11.5' room, the layout will be approx. 11.5' X 3' (except where I have the curves), it will be "L" shaped, and be a continuous loop type as opposed to a point-point. I will also have a work bench in the same room in one corner so I can work on my trains and other things. I like the look of my layout but these curves just seem GI-NORMOUS to me. So the smaller I can make them and still have my train steam around them at a good speed the better, A good speed be important because right now my layout is mostly curved track - there are two curves of more than 180degrees and one a little more than 90degrees. Any and all help would be greatly appreciated. Regards, Obi
