Stephenr216
I am about to buy an Atlas 2-6-0 N scale Mogul. Would I have to destroy the factory-installed rapido coupling to remove it? I've never changed couplings before, and I was wondering if when you did change them, is it a slide-and-click operation, or a cut, solder, and glue type deal? Also, is the Atlas AccuMate magnetic coupler completely compatible with the MicroTrains magnetic coupler? Finally, I can't tell if truck-mounted or frame-mounted couplers are more common in factory fresh cars...is it harder to switch to all frame mounted from half and half, or harder to switch to all truck mounted from half and half? The only two vehicles that I am sure I will own are the Atlas N Scale 2-6-0 Mogul and an Extended Vision Caboose (#01507), both of which have frame mounted couplers as far as I can tell. I would prefer to go with truck-mounted to help in the tight corners, but are there some cars (see link to picture of caboose below) that just can't be converted to truck mounted?
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXHCZ3&P=7
This Christmas gift for my wife is looking to get more complicated...I think I will end up becoming the railroad mechanic, and she will mainly drive the train and build the town. Is this what usually ends up happening, the man lays the track while the woman builds the houses? I just don't want this to turn into the proverbial "bowling ball" Christmas present . She really did bring up the idea for model train building as a hobby! We almost bought a set for her a couple of years ago while in a hobby shop.
-Stephen
-Stephen
