New Stock 27 turn motor, what size gear shall i use?
Discussion in 'RC Drifting and Setup' started by xaero187, Mar 2, 2005.
  1. xaero187
    xaero187 Guest
    i have just bought my self a stock 27 turn motor and i was wondering what gear to use? i have used a 21 tooth but it over heats. i'm running a tc3 with dr-01's, can anyone advise me please? cheers
    Hairybeastman@hotmail.com (it would be most helpful if i got replies to this email :eek:) thanx again)
  2. rcdrifter
    rcdrifter Guest
    what sort of speed conroller are you using...
  3. SpArKeY_STi
    SpArKeY_STi Guest
    Basic questions to help you...
    What ESC?
    What racing are you doing? (Drift, play, touring)
    What Spur Geat?
    What battries?
    What Connectors?
    What Pitch?
    I tend to gear it REALLY low for drifting as power is needed more then speed, and a electric motor should always be under geared abit.
  4. xaero187
    xaero187 Guest
    well i'm using it mainly for drifting around parking lots etc and the stuff i have on it are:
    m sonic rv 15 esc
    2400 mAH battery
    standard team associated spur which i think is a 72 tooth
  5. SpArKeY_STi
    SpArKeY_STi Guest
    your probly going to hate me for this, but on the Team Associated website, they have a tooth tuneing guide. And if it was bought new, it should also be in the back of the manual.
    But id go with about 21 or 2ish...
  6. xaero187
    xaero187 Guest
    well i'm using a 21 tooth pinion and it's over heating like crazy?
  7. SpArKeY_STi
    SpArKeY_STi Guest
    something with your motor is causeing overheating. Try re-setting your ESC, and useing the smallest pinion you can find... if that doesnt work, id have a tech guy check the ESC and Motor...
