New scratchbuilt structure
Discussion in 'Photos & Videos' started by shamus, Dec 4, 2002.
  1. davidstrains
    davidstrains Active Member
    Rich, mine came off as a jpg. I did the right click of the picture to save the attachment. Didn't remember to check the ext. until I decided to print it out. HTH.:)
  2. Edavillenut
    Edavillenut Member
    Great model.
    do you have the HO scale version. I would really like to try to build one.
  3. kettlestack
    kettlestack Member
    Shamus, Every last one of your structures is so perfect in concept, theme, weathering and detail that words just fail me!:eek: :eek:
    You're trully a masterbuilder and of course being a professional photographer your photos are fantastic.
    My hat stays off to you sir :)
  4. davidstrains
    Shamus, another quick question. What is the top to bottom measurement for the wall piece with the 3 windows stacked 3 stories? That is a good reference for the rest of the structuure heights. Thanks again for your expertise and patience with us "newguys".:) :)
  5. Matthyro
    Matthyro Will always be re-membered
    A great addition to the BC group Shamus. Soon you may run out of room going the way you do. Did you base it on anything is did it come from your imagination.
    Just beautiful workmanship and detailing
  6. Drew Toner
    Drew Toner Member
    Yes, master modeler for sure:) :) :)
    Shamus, I see that the structure has at least nine different chimneys!! That building would be good up here in Northern Alberta, would be able to keep warm!
    Are we going to have a contest for December?
  7. shamus
    shamus Registered Member
    Hi Gang, Once again, many thanks
    Rich if you just (Right mouse click and save as) it will save as a jpg the right size.
    David, I have put up another drawing with some mm on it for you.
    Robin my friend, that is a lookalike FSM structure I fell in love with.
  8. davidstrains
    Thanks Paul. Now I have to go find a MM ruler.:D :D :D
    This will help.:) :)
  9. rich maiorano
    rich maiorano Member
    me too!!! thanks paul :D :D :D :D :D :D rich
  10. 60103
    Milly Meters
    Guys: do you know that in Europe, the standard is that engineering drawings are labelled in millimetres? It sure looks stange when you see a drawing of a railcar and it's 24685 long.
