New project,looking for some imput
C
Catt
I just bought this,ain't she sweet?
Other than stripping her and repainting for the Grande Valley I can't decide if I want to keep her an FP45 and just remove the steam generating hardware or cut her down to a F45 configuration.
The plus side of keeping her a FP45 is I would use a ATLAS SD60 mech which is Plug&Play.
If I decide on making her her a F45 I will be using a KATO SD45 mech which is not Plug&Play,
I am beginning to wish I had found two of them so I could do one of each configuration. :D
railohio
999
You didn't take your meds today, didja, John? :D
I'd say keep it a FP45. You can always keep it in dual service, look at the Santa Fe. Try putting a F45 in passenger service, though, and you're going to have some durn irate passengers! :D
C
Catt
I've decided that the FP45 will be rebuilt as a F45-3 but retain the FP body unchanged except for removal of the stearm generating equipment.
I have already replaced the rear pilot with one from the donar SD60MI used the stock FP45 front pilot but that is going to be changed to the front pilot from said donar SD60M.Using the SD60 mech makes DCC plug&play though I will most likely end up using a Richmond Controls lighting unit to get the lighting that I want.
I still haven't decided on a colour scheme for the next generation GVR. Anybody got any suggestions?
Charlie ,passenger opps on the GVR are handled by AMTRAK and a to be built yet light reail system.The GVR is shopping for suitable railcars and has given thought to some refurbished PCC cars.Any suggestions from the Gauge crew would be welme. Juist remember this is N scale.:D
Oh yeah the fans will be replaced too.The old Lima fans don't look bad but the KATO SD40 fans look sooo much better.
C
Catt
In the picture above the steam heating equipment is between the last fan and the backwall of the shell.The trick is going to be to shave it off wuth a chisel blade with out damaging it or the roof.
Most people won't even realize that it has been removed unless they are told.
The more I look at this picture the more I find I want to change. :D
C
Catt
Project update
Here's a couple update pictures showing the front and rear SD60M pilots installed but missing their railings yet.
She is setting on the second SD60 mech as the first one has developed a highpitched howl.Things to do yet include replacing the fans blanking out the headlights on the cab front and possibly adding freestanding grab irons.
Oh,and of course a paintjob.
C
Catt
Progress report
Thought I'd plop a progress pic in here to let anyone interested see whats going on with the ol girl
Since this pic was taken I have created and installed jacking pads which LIMA kind of forgot to install.
