new guy with wiring problem
Discussion in 'FAQs' started by goatman, Nov 23, 2002.
  1. goatman
    goatman New Member
    I am wiring 10 blocks on my new layout with Atlas selectorwith[4switches] in each section for a total of 4 section for some reason witch a can't understan acan"t isolate my blocks no matter witch swich Iuse .Iused plastice rail joiners on both rails any help please.thanks in advance.jim[goatman]
  2. Tyson Rayles
    Tyson Rayles Active Member
    Diagram of trackplan w/insulators marked would sure help.
  3. Clerk
    Clerk Active Member
    Could you post a drawing so we can see what you did?
  4. billk
    billk Active Member
    Actually a wiring diagram of what you're doing would be of more help than just a track plan. I think. Maybe. It might be a real pain to draw one up, but you might just figure out on your own what you're doing wrong by doing so.
    Another thing is to get or make a continuity tester if you don't have one already. It can be as simple as a couple of pieces of wire, a battery and a light or buzzer.
  5. shamus
    shamus Registered Member
    Hi Jad,
    I would prefer a simple trackplan to solve your problem, with a plan I can re-draw it and place in where to put DPDT switches and where to place "Plastic" rail joiners.
  6. goatman
    goatman New Member
    thanks guys for your replies,i can't draw any plans,but idid some testingand i think my prolems are in myAtlas selectors . Iget a short across all the terminals with nothing attached. Ihave some oldSP/DTswitches that I will try.let you know how i make out ThankJim:)
  7. goatman
    goatman New Member
    wireing problem solved
    Had two wires mixed and had a plastic insulator that was no on the rail everthing is OK thanks Imust have had fishing on my mind when I was working on the layout. JAD:) ;) :cool: :rolleyes:
  8. tomfassett
    tomfassett Member
    Re: wireing problem solved
    What? You say that like it is a bad thing... Now if I could just figure out how to take the layout with me when fishing, I would be in heaven...;) :D
    Tom F
