Discussion in 'RC General & Getting Started' started by mxmx995, Dec 24, 2003.
Thread Status:
  1. mxmx995
    mxmx995 New Member
    HEY Im just brought a new kyosho ultima gp stadum truck and i wanted to know if the GX-15 engine is fast or should i get the o.s .15 cv-x.or traxxas 2.5 and would the fit?
    (o.s .15=$80)[?]
    (traxxas 2.5=160)
  2. bandit1
    bandit1 Member
    go with the o.s .15 cvx. only because i have seen really good reviews on it and its fast.
  3. Steve M
    Steve M Member
    OS quality is very hard to beat. The Traxxas 2.5 motor seems to be very powerful as well and it comes with a nice warranty too. I'd run the GX-15 until it wears itself out first before upgrading.
  4. mxmx995
    mxmx995 New Member
    what will the o.s give me in accelaration speed & top speed more or less than GX.15 or traxxas 2.5
  5. trxtalon
    trxtalon Member
  6. CaNaDiAnRaCeR
    CaNaDiAnRaCeR Member
    Try the Epic .18. I'm going to get it for my stadium truck. They say it has 1.8hp @ 39,00RPM. It should fit anywhere a small block could fit. Also it has a low price, $140.
  7. oliver
    oliver New Member
    If I can make a suggestion,Get yourself an R&B motor,I ve been doing 1/8 scale buggy racing for 6 years and used OS and R&B motors and R&B ROCKS!!!!!!
    If you know anything about aircraft,Check out or find out about a Nova rossi Motor (usually used for the F1 airplanes).R&B is Nova Rossi motors tuned to perfection... Here is an example of one
  8. Use the engine you have until it wears, and the os will depend on the gears you use
  9. dudex
    dudex Member
    I agree with danny. If this is your first car, make your mistakes with the stock engine, not a nice new one. I would buy the os just because they are easier to tune. If you want more power than the .15cvx then get the .15cvrx.
  10. rockn82
    rockn82 Marx Brother
    Be wary of the traxxas 2.5. They have lots of probs with premature wear and lots of bad piston/sleeves. The plastic bodies on the carbs are prone to hairline fractures too. Also I have been seeing alot of carb binding due to the fact that the slide digs into the plastic body of the carb although that isnt hard to fix.
  11. luch90
    luch90 Guest
    get a fantom fr15 and dont look back fantom motors fly[8D]
  12. mastmec
    mastmec Member
    If you want a good, reliable engine go with an OS or NovaRossi, both are great and easy to tune and deliver great power.
  13. DangerRanger
    DangerRanger New Member
    WHEREdo i get the ?o.s .15=$80)[?]Thanks
Thread Status:
