New airbrush, need compressor
Discussion in 'On30 Forum' started by fsm1000, Jul 22, 2007.
  1. fsm1000
    fsm1000 Member
    I finally broke down and bought a cheap [really cheap, 8 bucks] air brush. I am now looking into getting a very quiet compressor if one exists.
    It only needs to be between 15 and 35 PSI.
    I know nothing about this so all help is appreciated.
    Thanks for all your help ahead of time. :)
  2. steamhead
    steamhead Active Member
    Stephen...I presume it is a small modeling airbrush. There are many small compressors - check out Micro-Mark. Just be sure to get one with an air tank, even a small one, so you don't work directly off the compressor.
    Good luck..!!
  3. Nazgul
    Nazgul Active Member
  4. fsm1000
    fsm1000 Member
    Gus, thanks, I am leaning towards a large tank as it will only have to fill once or twice [I assume] and therefore make less noise. Thanks for the hint :)
    Steve, I will see if they sell that one up here. Thanks :)
    [nice name by the way LOL] :p
  5. I worked for years with a compressor which came from an old fridge...
    costs nothing if you can find one..
    Cheers, Billy aussie
  6. fsm1000
    fsm1000 Member
    billy thanks, good idea there :)
  7. fieromike
    fieromike New Member
    You mention quiet as one of your wants. All diaphragm compressors are noisey, but one made from an old refrigerator or window a/c compressor will be the quietest. Make sure that you use an oil separator, or you will be repainting a lot! Another option is the conventional piston type air compressor. Durable, but usually bulky and heavy for hobby use.
  8. fsm1000
    fsm1000 Member
    Mike thanks for the insight :)
