Need Some advice.
jflessne
I have a unindentified brand of IC coil car that came to me in bad shape. I'm currently putting metal wheel sets and new Kadee couplers on it. I recieved the coil car with one truck detached and missing the pin that attaches it to the bottom of the frieght car. What are these pins called? Or should I replace it with a screw?
Also does anyone know who made this model?
wickman
I'm sure just the small screw into a tapped hole will work for the wheel sets to the body. I have no idea what kinda car it is .:wave:
brakie
First that looks like a old AHM coil car..This car was also release by IHC and maybe ITT.
I would just use the pins since this car is no longer available.
MasonJar
It's not rocket surgery
You can replace it with a screw, if it is the right size hole. If not, you can plug it with styrene rod and drill and tap for a screw. If you don't have any styrene rod, you can melt and stretch a piece of plastic sprue to make your own... :)
Alternately, if you have any spare part from Accurail kits, you may find an extra pin in there. Don't know if it'll fit...
Andrew
jflessne
Ya know AHM was the first thing I thught of....the truck mounted couplers are similar to my passenger kits I'm upgrading.
jflessne
I'll try to find a pin or a screw. I haven't gotten into scratch building items yet. As you can see from my signature I'm terrible with glue etc. :)
