Need help!!!
Discussion in 'RC Offroad Forum' started by mxmx995, Feb 1, 2004.
Thread Status:
  1. mxmx995
    mxmx995 New Member
    Why can't I start my kyosho ultima gp and have it sit in idle without moving on the ground Like my friends (StreetForce).i know its direct drive & single speed trans. So do i need to buy a different trans or an idle gear or something?? .If so which one whould fit in work.............................thanks[?]
  2. mastmec
    mastmec Member
    It doesn't have a clutch?
  3. mxmx995
    mxmx995 New Member
  4. mastmec
    mastmec Member
    Sounds like you first need to check your clutch, the bearings and spring. loosen the engine so it will seperate from the spur, spin the clutch it should have no friction and should spin freely. For the two speed clutch bell you would also have to have the two speed spur gears and clutch assy. if it offered for that car, I'm not sure.
  5. mxmx995
    mxmx995 New Member
    ok when i spin it it has a lot of friction in dosen;t spin freely it's tight
  6. dudex
    dudex Member
    you need to replace the bearings probably. open it up and check if theres a lot of dirt or if somethings broken.
Thread Status:
