need help with bachmann plus gp35
Discussion in 'HO Scale Model Trains' started by Gina73, Apr 1, 2005.
  1. Gina73
    Gina73 New Member
    Hi..thanks.. I have a "new" old stock bachmann plus gp35 it runs nicely on fast speed...but when going slow it slows and screams...intermittently...anyone know what causes this...have seen it before with older trains...and what can i do to rectify it...i already greased what i could... i needed...and thank you
  2. nachoman
    nachoman Guest
    maybe a gear broke loose and is spinning on a shaft?
  3. Ray Marinaccio
    Ray Marinaccio Active Member
    Did you put a small drop of oil on the motor bearings behind the flywheels?
    That sure sounds like the motor bearings need oiled.
  4. Gina73
    Gina73 New Member
    well...i finally found out how to remove the cover...i lubed the gears and shafts
    ...runs good now...just loud though...wish i could dampen it...i need gear grease...can i use lithium?...thanks for help
  5. stuart_canada
    stuart_canada Member
    my understanding is that bachmann is always loud, not much can be done.
    but I like the spectrums and plus models i have from them
    would not trade them for anything
  6. NYC-BKO
    NYC-BKO Member
    As long as it's plastic compatible you can use any grease you want, I prefer Labelle #106 for gears and a light oil for bearings, make sure the worm bearings are oiled too. I don't have the GP35 but have other B-mann's and oil & grease quiet them down alot with some break in. I also oil [ heavier ] or grease the sockets for the drive, this helps quiet them down too! Be careful how much you put on the sockets as excess will fly off everywhere!!!
    My lube methods are a little different but any place there can be friction I lube.
  7. Gina73
    Gina73 New Member
    thanks guys! I went to a hobby shop and the man told me to use pinecar products white teflon dry i will give this a try...and a drop of woodland scenics..oil... ill let ya know... Gina : )
