Need help finding a canopy
Discussion in 'Aircraft & Aviation' started by Texman, Feb 24, 2008.
  1. Texman
    Texman Guest
    I am in need of a Mig-29 UB canopy, to fit the GPM no.091 Mig-29.
    The vendors I have listed are out of stock or don't carry it. Can any
    one help me out? PM me with the price if you can!
    Thanks y'all
  2. Rick Thomson
    Rick Thomson Member
    Dunno if you are still in Germany or not Ray, but if you are, you might try the modelling exhibition in Sinsheim from the 13th til the 16th of March.
  3. Texman
    Texman Guest
    I wish! We moved back to the US the first of the year. I know I
    could find them there at the expo. Thanks for the reminder Rick.
  4. jaffro
    jaffro Long term member
    I just noticed this new (to me anyway) idea for canopies in this thread, maybe if you can't find one to buy you could try to make one using this method.
  5. yaniv
    yaniv Active Member
    i am like jaffro
    way not to make one?
    its mach more eseyer and mach more fun to make your own cnopys :)
  6. Lex
    Lex Dollmaker
    Yea, I suggest vacforming too. I tried it and worked fine (save for a really nasty burn on the hand...) Besides, doesn't it feel good when you know everything is made by yourself? ;)
  7. exzealot
    exzealot Member
    Hi Ray,
    Send me a xerox or scanned images of the paper canopy parts, and the bottom profile from the fuselage, and I'll make you a canopy and send it to you. The copies must be to exact scale.
  8. OhioMike
    OhioMike Member
    Get one of the wifes or moms bakeing pans...the real old one that they dont use. Preferably a bread style thats fairly deep. Preferably with a drill press but a hand drill will work with perserverence, start drilling holes in the bottom. About a hundred or more in a grid fashion. cut a hole in the side that will fit a small vac. hose. now have a vacuform plateen! Theres plenty of sites out there to tell you how to heat your "Plastic"! I use a picture frame and clothes pin acetate or thin plastic to it...oven bake for only a few minutes at a fairly low temp to wear you see saging and place it over my mold/plateen with the vac running and....Walla!!!
