Need basic anti warpage advise
Discussion in 'Ship & Watercraft Models' started by garyj36, Jan 24, 2005.
  1. garyj36
    garyj36 Member
    I plan to glue down all my formers to the keel plate . But "not" glue the slots where the go together. I read somewhere that helps prevent warpage. But what about where the keel plates sections meet? Should they be solidly mounted together? We're talking waterline model with typycal multi piece keel plate and formers.
  2. murban
    murban Member
    first you should lay down the keel plat on a (really!) flat surface, adjust the parts to lie perfectly in line (check with a ruler, see Oregon thread) and then glue them together.
    Check again if the plate is straight and weigh down all the parts until the glue is dry (do not! use water based or white glue - use the smelly one...).
    After that, assemble the keel in pretty much the same manner.
    Then, put the formers onto the keel, apply glue to the area where the keel meets the keel plate (not to the formers) and glue the keel to the keel plate.
    Constantly check for proper alignment until glue is dry. Be careful not! to glue the formers at this point.
    When the glue is dry, remove all formers and then glue them on piece by piece, adjusting each one for right angle and alignment with the others.
    When all are one, let dry under pressure for at least a day.
    This is only one way to do this. The most important facts are:
    * Glue together all multi-part pieces first. Make sure they are perfectly aligned so that any warping can't originate from them
    * Always work on a really flat surface (glass plate). Your workbench usually isn't flat!
    * Never user water-based glue for the skeleton
    * Whenever possible weigh down the parts after they are glued on.
    And, never forget to wish yourself luck before you start.
  3. DN
    DN Member
    What I've discovered is that it is not so much not gluing the slots as keeping them wide that helps. It makes sense to me - tight slots introduce "bad" stresses in the elements. So I keep them wide and loose and glue them. Of course, everything what Michael says holds true.
