Need advice on Engine Assembly
Discussion in 'RC Offroad Forum' started by Starguard, Mar 21, 2004.
Thread Status:
  1. Starguard
    Starguard Member
    Hi Everybody :)
    I need a little advice on re-installing an OS 46FX Cylinder Sleeve and Piston. This is for a Nitro Powered Koyosho Racing Truck. With the truck facing me, exactly what position should the Cylinder sleeve be in to get maximum performance out of this engine. There are several ports on this sleeve and I need to know exactly which direction each port should be facing...Thanks in advance!
  2. mastmec
    mastmec Member
    You have to match the ports in the sleeve with the ports on the block, easiest to see is the exhaust port. Is there no small pin on the top of the block to match with a small notch in the top of the sleeve?
Thread Status:
