NCE & EZ Booster
dtsteam
I'm considering attaching the basic NCE power cab to an EZ Booster. I'm assuming that the track out from the basic NCE system is the input to the booster. The spec for the booster says that the input is opto isolated. Can I still use the original track feed for one power division and the output from the booster for another ?
baldwinjl
I think the answer to that must be yes. The Booster isn't going to load the power cab to any significant extent, so I don't see why it won't work. You will want to make sure the polarity at the track matches to avoid a short when you go from one district to the other, I think.
Jeff
