N scale truck mounting
COX 47
123
How can I put Trucks on N scale cars . Ihave some Model Power I'd like to use screws like HO Athearn. What do you use to fill thehole,Self tapping screws? What size and where would I locate them? Anybody Who has done this give me any help? Thanks Cox 47
ezdays
Out AZ way
Feb 3, 2003
6,339
Arizona
bigbluetrains.com
I first try to use the plastic plug that holds the truck to the car. When that doesn't work, I have an assortment of small sheet metal screws. Sometimes I use a drill bit as a reamer to open the hole to fit the screw or an oversized plug.
I'm sure there is someone here that has a better idea than that. ;) ;)
Bikerdad
164
Southwestern US
Generally, you can drill and tap for a #2-56 flathead or ovalhead screw. Using a flat or oval head screw will automatically center the truck. While you may use self-tapping screws, that presents potential for being off-center. Use a tiny dab of blue threadloc to keep the screw from loosening, and you're all set. (just a tiny dab, so you can remove the screw when you want to...)
